2021-09-05 10:45 PM - edited 2021-09-06 05:52 PM
I'm currently working on the schedule set up.
-Is there a way to make the width / height to show the full dimension such as 3'-0" instead of 3'?
don't like the formatting since some shows 3' then some will show 2'-6" etc.
-How can I include the sidelights in the door schedule, right now it just only showing the french door width of 6' and not showing the 3' sidelights on both side a total width of 12' opening.
thanks.
Solved! Go to Solution.
2021-09-06 02:05 PM
@sknsnw9 wrote:-Is there a way to make the width / height to show the full dimension such as 3'-0" instead of 3'?
The Schedule should be a View, which has View Settings. In the View Settings, use the Dimensioning pop-up to set the Dimension preferences, which are set up in Dimensions under Project Preferences (look at Display of Zero Feet & Inches there).
2021-09-06 02:05 PM
2021-09-06 05:03 PM
Awesome! Thanks. Thought there had to be a setting somewhere! Thanks for pointing me in the right direction.
