Wrong decimal digits when publishing
Hi!
I set every settings to 2 decimal digits in my program, but when I'm trying to publish my plans, the annotations are changing to 3 digits. How can I fix this problem? I took screenshots of the problem.
Thanks,
Alex
1 Solution
vistasp
Welcome to the forum.
You need to save the view with your preferred settings before you place it on the layout otherwise they won't "stick".
Read up on "view map":
https://helpcenter.graphisoft.com/user-guide/64901/
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Go to post
2 Replies 2
vistasp
= v i s t a s p =
bT Square Peg
Thank you! It helped, now It's working.
