ZONE: show floor finish and floor level?
in AC22, I am looking for a way to force ZONE to automatically show actual floor finish of the slab and its level (not using custom text). Is it possible?
Thank you
6 Replies 6
Hello tranthainguyen,
You are able to call all properties you need into Zone stamps by "Classification and properties" and "Zone_Stamp_2_XX"
About Floor/celling/wall finitions I prefer create my own properties to call them easily.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Hi Christophe,
Thank you for your reply.
However it does not automatically read the floor finish of the slab. Also I can't get it show the level of the slab either. Please see screenshot
Could you show me how to make it work?
Thank you
Lingwisyer
Guru
As far as I know, the Zone will only show the FFL offset from the Story Level.
Hi Ling,
Thanks for your reply.
It seems that ZONE cannot pick up the finish surface and level of the floor. Am I missing something?
Lingwisyer
Guru
See this thread regarding Properties.
It seems there is no relationship between zones and slabs for some reason.
Here are a couple of posts that highlight the problem.
https://archicad-talk.graphisoft.com/viewtopic.php?f=34&t=66845
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=66671
