2008-03-19
02:55 PM
2025-02-06
11:14 AM
Aruzhan Hamar
2008-03-19 03:59 PM
2008-03-19 04:43 PM
goose724 wrote:Type "\n" where you want the split (no quotes). You may have to add the same
Is there a way, or does anyone have a tool, that enables you to type the ZONE NAME on two seperate lines?
2008-03-19 04:49 PM
Stress wrote:However -- this doesn't work so good if you are listing the Zones in a schedule (the "\n" appears within the Zone Name)
Type "\n" where you want the split (no quotes). You may have to add the sameat the beginningof the text below (room #) etc., so not to overwrite.
2008-03-19 04:56 PM
Laura wrote:Very true. Also, i just realized, if you show calculated area, there's no way to add a line. The text will be overwritten.
2008-04-12 03:29 AM
2008-04-17 09:50 PM
goose724 wrote:May be this can help. From the Zone_Stamp_02 INT library.
Is there a way, or does anyone have a tool, that enables you to type the ZONE NAME on two seperate lines??
2008-04-19 06:06 AM
2008-04-19 08:53 AM
Erich wrote:Sorry, i was unclear, i mean multiple lines in floor plan window only.
Are you saying that the stamp will create two lines in a zone name definition in the schedules?
2008-04-19 12:57 PM
Olivier wrote:The schedule behavior is independent of the stamp. Word wrap in schedules is a wish, essential IMO.
don't know if it is possible, to display zone name on several lines in schedules.
