2015-11-17
03:50 PM
- last edited on
2023-05-23
12:09 AM
by
Gordana Radonic
2015-11-18 01:21 AM
2015-11-19 09:55 PM
jfa_ra wrote:
Is is possible to have ONE zone stamp display different content components in different views that have the same scale?
For instance, the zone stamp will display the Room Name, Measured Area and Room Number on the 1/8" Floor Plan, (which has a scale sensitive setting of 1:100).
The same zone stamp will display the Room Name, Floor Finish, Base Finish, Wall Finish and Ceiling Finish on the 1/8" Finish Plan, (which also has a scale sensitive setting of 1:100).
This would be easy to achieve if the Finish Plan was defined as 1/4", then the scale sensitive setting would be 1:50). (Unfortunately the Model View Options does not allow you to define more detailed zone display properties which could be assigned in the View Settings.)
While creating a duplicate zone on a different layer could achieve the desired output, that would introduce a host of coordination issues that is undesirable, unnecessary and not very elegant.
Thoughts?
Regards,
Joe A.
(ArchiCAD User since 8.0)
2016-11-16 09:13 PM
2016-11-17 09:31 AM
