2022-09-05 08:39 AM
I need some help disabling the way zones extend over the border line and into door openings.
I have disabled every option in Project preferences > Zones, but the thing still does it!?
How do I fix this issue! Please help.
Thank you.
Solved! Go to Solution.
2022-09-05 09:34 AM
2022-09-05 09:23 AM - edited 2022-09-05 09:27 AM
Edit: My mistake, just saw you did everything. Is calculated area correct? Did you update the zones after unchecking the settings?
2022-09-05 09:24 AM
If you check the picture I posted, I did exactly that and it still does it.
2022-09-05 09:27 AM
Sorry, my mistake, just edited my reply
2022-09-05 09:32 AM
Hmm yeah It seems the calculated area is wrong, its adding those parts under the door... Should be 2,9m instead its 3.16m. How do I update the zones now that I've unchecked the setting? Thanks
2022-09-05 09:34 AM
2022-09-05 09:47 AM
Thank you, this was the missing part 😅
