Display malfunction of Graphisoft ID dashboard
Learn more
Zoom-In / Call Out Construction Detail Drawing
Dear All,
I couldn't find the answer for it, so hoping that someone can guide me on how to do a Call Out.
What I mean is that, I am doing a section cut drawing. And wanted to do a part section for construction detail drawing on the Walls + Interior Cladding + Exterior Cladding. To show very detail of the walls layer etc.
My question is, how and what should I click to get to that Pull Out drawing of my walls details ?
The 'Detail' tool allows you to isolate part of a plan, section or elevation and view this in a separate window at a different scale.
It will only be as detailed as your model is but you can annotate with extra lines and fills you get the detail you want.
Something you will need to be aware of is that these Callouts will not be live model portions. They will be Drawings generated from the Viewpoint the Drawing Marker is placed in. However, you can update/regenerate the Drawing's content if its source Viewpoint changes.
