2003-10-29
07:21 PM
2025-02-10
05:07 PM
Aruzhan Ilaikova
2003-10-29 07:39 PM
2003-10-29 07:44 PM
2003-10-29 07:46 PM
2003-10-30 05:35 AM
~/archiben wrote:It will be refelcted in all the layouts that have that master selected in the layouts settings. One lbk can have many different size sheets based on the number of masters you have. One master is set as the default (bold in the list) which is what all subsequent layouts will be.
ok
so if you go to "master layout settings" at the bottom of that drop down list you will be able to change the paper size (via plot/print set-up) for that "master". it will then be reflected in all of your layouts.
~/archiben
2003-10-31 01:58 AM
2003-10-31 10:25 AM
Bruce wrote:and if you are using a mac: switch to the finder and locate the layout book file, select it and "Get Info" (Cmd I). in the floating window that pops up you change the files 'type' to a "Stationery Pad" and 'lock' it.
A further guard against editing is to save the Layout file without any drawings like the GS example.
