Hi!
I have a project composed of 3 hotlink modules. The common pln embedding 2 external modules has a different project 0 than the external hotlink files.
How can I set a door marker so that it references to the project 0 of the external hotlink file?
In the external hotlink module, the door marker and the lintel height is shown correctly: referenced to the hotlink "0", but if I open the whole project that embeds that hotlink module, the door markers lintel height adapts: it references the new project 0.
Another solution would be if I could set a custom anchor point for the lintel height, Is there a way other do that?
thank you in advance
