details from 1 file to another? - best way?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-05-14
05:37 PM
2023-06-07
03:07 AM
Gordana Radonic
Whats the best way of getting some standard details fron 1 archicad file / project to the other? (without too much work!)
Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-26 06:13 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-26 06:16 AM
AC27 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-26 06:27 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-26 03:15 PM
Brett wrote:I don't get your point.
The reason I said definitely 12 for the observant one's
You asked why you couldn't see the option ( Blind?) and the answer is that you are using the wrong version of AC. The screenshot from the manual, previously posted, states clearly that this is a AC12 feature and you posted a screenshot of AC11's Publisher as proof that you can not create PMK's, and that there is NO documentation in the Help Files?
____
Let's review
I referred to the specific page in the Reference Guide, and made a bad joke about searching pdf's (reason why there were Winks at the end of the comment).
Because those pages DO say something about it I posted the screenshots to try to help.I wrote the procedure and posted were to select the option. I also posted part of the referred manual underlining the relevant options.
Then you posted with a screenshot that does not show PMK as an option.
Yes thanks, but? I think I must be blind.Definitely AC 12 Publishing method "save"Which I took to mean that you cannot find that option in your publisher. Then I reread your signature and see that you are using AC11 which does not have this option so obviously you cannot use it and you confirmed that is the case.
______
Apparently my mistake was assuming that since you asked how to do something in AC12 you had that version and sent you to read the manual. I did this because you said that you had searched the help files and there was no mention there of this Feature and that the feature was unavailable in the Publisher;
Brett wrote:
Could someone please point me to the instructions for saving a view as a PMK in 12. I've looked in help and there is zero information for a "new feature".
Brett wrote:________
Been there,done that, but if you look at both those pages it says absolutely nothing about how to. I can't find anywhere in Publisher to save as PMK. Nothing under "Publisher Set Properties". Nothing under "Document Options"
What I don't get is Why you wrote that you can't find or do something if you know that you don't have the correct version of AC?
If I offended you I apologize but I feel that I have wasted my time answering your question.
AC27 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-26 04:04 PM
I may have missed something but
just thought I'd note that
I don't have a pmk option
in 12 full.
So maybe it's something you have to turn on?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-26 04:13 PM
You can save Views as PMK not Layouts.
I'll edit my previous entry. Brett if this is the mistake (and source of my confusion) I apologize again.
AC27 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-26 11:36 PM
Cracked it at long last, Drag a "View" straight from the View map and then the PMK option appears in the publisher. Never done this before (view to publisher) What do people use this for,any advantages?(apart from PMK)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-27 12:30 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-27 12:52 AM
Seems PMK is not a reason when using them for details.
How hard can it be to drag an independent detail from one project to another without having to set up another blank independent detail in the target project.
- « Previous
- Next »
- « Previous
- Next »
