Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
dimension lines thickness
Hello.
Can I change the thickness of the dimension lines? I would like them thinner than default.
Thank you.
4 REPLIES 4
igreere wrote:
Hello.
Thank you.
Dimension line pen controls both the dimension line and the witness line. Did you want these to be different?
Yes, exactly. I want those different. I might know what to do - change the colour of all dimension lines to a certain colour and then go to pen lines and then ascribe a thickness to lines of that colour. Is there another or simpler way?
Eduardo Rolon
That is the simplest way.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Then problem solved. Thank you.
