We value your input!
dimension marker visualisation problem
Hi everybody!
I have a problem with archicad21. On the existing plan view I insert the windows dimension marker, I would like to visualise it on both existing plan view and planned status view. While on new construction view I would like to see only the windows without dimension marker. The same things is for the new windows dimension marker, I would like to see the red new windows without dimension on the new construction view and the windows with dimension marker on the planned status view. How can I do it? I hope my request is clear. Thank you.
4 REPLIES 4
Erwin Edel
You can create any amount of renovation filters where you control for all three status (existing, demolished, new) if you want to display markers.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Thank you for your answer. I don’t understand how more renovation filters can help me to solve this problem because the dimension marker is a feature of the windows (and the same for the doors).
Erwin Edel
https://helpcenter.graphisoft.com/guides/archicad-20/archicad-20-reference-guide/views_of_the_virtua...
Hide Opening Dimension Marker (if you don’t need to see dimensions of openings already in place)
www.leloup.nl
Windows 10 Pro
Thank you so much! Now I understand, you were really helpful
