2011-12-12
04:45 AM
2023-05-22
11:59 PM
Gordana Radonic
2012-07-19 03:16 PM
2012-07-25 01:55 PM
2012-07-25 03:40 PM
2012-07-25 03:49 PM
2012-07-26 04:09 AM
Erika wrote:But be carefull. When you change your partial display option again the dimensions will disappear. They will only show in the partial display option that they were created in - a bit like turning layers on and off.
When you are dimensioning core only, in addition to setting dimension to Dimension Core Only, set your MVO to display Core Only. Then you will see the end point of each core.
2012-07-26 11:03 AM
Barry wrote:.. as I discovered! This seems to defeat the object. Not much point in being able to dimension to the core, if you can't see the dims in the general view!
Barry wrote:A rather useless feature, I'd have thought. How much better if you could snap on any of the intersections, just as you would when the 'dimension to core' option is off. (The option does say 'dimension
Is this a bug or a feature?
2012-07-26 03:38 PM
Keith wrote:Not sure what you find inaccurate but if you explode all your 3D elements you are creating many more areas for possible error.
I'm still reeling from this experience which is both incredibly time-consuming and inaccurate, and wondering whether in future I should explode walls to lines just to be able to dimension quickly and accurately by ensuring I've snapped on the correct junction!
2012-07-26 04:30 PM
2012-07-26 09:45 PM
If, however, you need to dimension to the core, this facility no longer existsKeith,
2012-07-27 04:26 AM
