dimension's problem in elevation window
Hello
I have a problem with dimensions in elevations window, because i do not see it, it is too small to see anything. In order to see anything i have to type huge number, for example, type text size 500mm. Also the same with marker's size, axes and so on. Everything fine with dimensions in plans or section's windows.
Maybe anybody knows where is the problem?
Work with AC 12, on Mac.
4 Replies 4
Rod Jurich
By chance, do you have your setting for text
set to PAPER Size not Model.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
The problem is not there, because it is marked paper size (scale). The problem is only in elevation window. It is seen on picture that i type 100mm symbol "a" and it is big in a window, but when i click with a mouse to put it in the window, the "a" comes enormously small that can not be seen.
The sample with dimension problem in elevation window
What is drawing scale? If you work with large scale, then this may be. Could you show more detail you views.
