dimensioning
Dimensioning of doors and windows on the entire bldg floor plan have shifted from center of object to edge of object. How do I fix this? Thanks.
9 Replies 9
Please see this thread.
http://archicad-talk.graphisoft.com/viewtopic.php?p=120673&highlight=dimension+window#120673
It appears to be the same problem.
You should add your version number, platform, etc,
to your signature for more accurate help.
Peter Devlin
Thanks Peter
Do I need to keep the "Show Edible Hotspots" ON under the Marker Settings when dimensioning to the center of windows and doors?
socoarchitect
v10
The thread I referred to did not have any clear resolution to this issue.
I work in AC 10 but have not seen this happen. The author of
that thread mentioned dimension markers jumping around as well
though his image does not show markers. I would try posting on
that thread asking if any more information has been developed
or if a resolution has been found.
Peter Devlin
What you mentioned worked for me. Thought you'd answer my question. It's ok. I agree, there were no clear solutions.
socoarchitect
imac g5 ac v10
I did not answer your question because I did not know the answer
to your question. As I said, I have not experienced this problem and
besides I do not use AC windows and Doors. So, you seem to be saying
when "show editable hotspots" is enabled the problem goes away.
Is this correct ?
Peter Devlin
That is correct. So far...
socoarchitect
socoarchitect wrote:
Thanks Peter
socoarchitect
v10
If I understand right the checkbox you are referring to is called "Show Editable Hotspots on UI" (User Interface). If you check it small red arrow will show the directions those editable hotspots can be dragged. But this setting has nothing to do with Automatic Dimensioning so you can check it or leave it unchecked.
I was surprised to find the fix to the dimensioning problem to be associated within the Marker Settings for window and door selection settings. I even unchecked the box and the dimensioning was fine. It's got me...
socoarchitect
v10
socoarchitect
v10
My guess would be that there is some hotspot ID that is taken by the marker when showing and by some other hotspot in the window/wallhole when the marker doesn't show. And that the dimension is attaching to that.
