ā2022-04-18 02:01 AM
I have doors and windows, whose text indicating the height and width are inverted reading orientation, the attached image shows that some are right others not, can anyone help me with this?
Solved! Go to Solution.
ā2022-04-18 11:29 AM
I think it might be the wall angle is not aligned to the X axis. Could you check that?
| Archicad 4.5 - 29
| HP Z840 | 2Ć E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| Archicad 4.5 - 29
ā2022-04-18 04:07 PM
I verified that it is aligned on the X axis as it should be, or it is imperceptible, I tried to align it with a horizontal line and nothing happened, I also dimensioned it with another horizontal wall, and it was exactly 180Āŗ.
ā2022-04-18 10:20 PM
@engjeancarlos Sometimes the only way to force AC to be on the X-Axis is to drag the wall away by a significant amount and then reset it either by snapping to the X-Axis or entering the angle in the tracker coordinates.
ā2022-04-19 04:47 AM
I would agree, the wall on the left (markers read from the left) is not exactly horizontal.
ā2022-04-19 08:33 PM
were right, the wall was crooked
