‎2006-12-21
12:33 PM
‎2023-05-30
03:23 PM
Rubia Torres
‎2006-12-21 02:53 PM
‎2006-12-21 03:07 PM
‎2006-12-21 08:51 PM
‎2006-12-21 10:49 PM
‎2006-12-21 11:45 PM
WENDY_NEVERLAND wrote:You could just shift select all the dimension texts and change them at the same time. Made easier now with quick select, so make sure you have that indented in your Info Box.
you are rights about the slab thing david but for the elevation level text i was looking for a way to make them all at once. one by one takes a lot of time. thanks a lot🙂
‎2006-12-22 10:02 AM
‎2006-12-22 11:44 AM
atab wrote:Will this work for all slabs that show their faces undesirably in section or elevation? This problem drive me nuts.
If you enter the settings of the slab, and under "outlines" and "uncut Line Pens, you select a white pen, to make it blend into the background.
‎2006-12-22 11:53 AM
‎2006-12-23 02:09 AM
WENDY_NEVERLAND wrote:It shouldn't change the actual dimension, just the additional text.
yes i could but it would also change the number of my level dimension.
thanks guys
