expanded edit toolbox in 8.1
Morning ,
Could someone direct me to the operation for expanding edit tool box ie.
drag a copy, rotate a copy etc.
Also I'm having trouble inserting dimensions into an existing string. The command isn't responding. I'm identifying the string, but when I SHIFT , APPLE (key) nothing happens.
2 REPLIES 2
David Maudlin
Marks:
If I follow your first question, look at Options > Preferences > Miscellaneous... and check "Show Element Copy Transformation Commands in Edit Menu".
To insert a dimension into an existing string, select the string, then hold down the Command (Apple) key while clicking on the point you want to insert.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks for the assistance.
