line division
dhnguyen
which tool palette do I turn on that will give me an option to divide lines into different segments?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
3 REPLIES 3
I do not think there is a direct command that would do that.
Could you post a screenshot of exactly what you are trying to achieve.
dhnguyen
I just recently installed ACAD on my new computer, so I had to go and find the palettes that I usually use.
I found it, it's the "Contro Box" palette - here is the snapshot of what I was talking about.
DNguyen
ArchiCAD 18- 25
Ah, OK, I thought you want to split a single line into 4-5 individual line segments.
In ARCHICAD 18 you will see the Special Snap Points button in the Standard Toolbar. It contains the settings you are looking for.
