problems
I am trying to use measure tool when drawing walls so i can give the wall distance and ankle so it takes exact dimensions,until now it used to work but now,when i press wall and measure tool together,the measure tool only works,is there any setting i have to do?thanks
Never use the measure tool to create objects.
When creating elements you must type in the exact value that you want for any element. You can turn on the Tracker and enter the value(s) there, or you can use the Coordinate Palette. Doing anything else is a sure way to introduce error into your model.
Karl
LOTTA THANKS!!
