structure label - text order
Hello!
I have a problem with labeling walls with structure label.
When I set it to show skins and its widths archicad first shows width and then skin name.
It should be the other way around. Is it possible to change it?
2 REPLIES 2
If the parameter settings don't allow the change it would require editing the script.
I thought so, and even opened script, but I think this is something that requires some advanced GDL scripting skills.
