trace is moving around
The situation: I imported xRef into a worksheet (in the original location) and then move the trace of this xRef on my drawing position.
Problem: every time I close the file and reopen it, I have to move the trace to my drawing position.
This happens even if I import xRef to the project origin or on the same "spot" as my drawing... Is this a bug or am I doing someting wrong?
Steve Jepson
It could be that your User Origin is relative to a grid? Did you check your Absolute/Relative Coordinate settings ?
