transfer or copy/paste dimensions from one file to another
Is there a way to transfer or copy/paste the dimensions from ArchiCAD file to another? I am working in the same drawing file one is dated differently than the other but it is the same building. Is there a way to transfer or copy/ paste the dimensions from file 1 to file 2? I tried just copy paste but not all the dimension strings come...?
Working in ArchICAD V.12
1 Reply 1
You would have to make all your dimension strings "static" so they are no longer associated with any elements.
This could be a problem if you want to redesign your model as your dimensions will have to be ammended manually.
Otherwise I think you have to copy across the element the dimension is attached to as well for them to remain associated.
But then you will be doubling up your model.
