where is Exterior Dimensioning
hi dear
in archicad 12 i can't find
Document > Document Extras > Automatic Dimensioning > Exterior Dimensioning
to use Exterior Dimensioning
it's not in menu bar
David Maudlin
tamtamtmatem:
The first thing to check is which Work Environment you have enabled. Go to ArchiCAD > Work Environment, select the Work Environment Profiles at the top of the left panel, then select "Standard Profile 12" and click "Apply Schemes of Profile" and click OK. This will set your Work Environment to the standard one. If this doesn't help, then you should post more information about what is not appearing on screen.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
thanks very much you solve my problem
