[zones] Zone fills in sheet/plot
Hello again,
sorry if this topic was mentioned before, but i wasn't able to find the solution on my own (even google didn't help at all)
Is it possible to turn off zone fills in prepared for print sheet? As suggested somewhere, i have turned off display of zone's background in model view options (Alt+Shift+2) but it is not affecting final plot.
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
Hi krriv,
The solution is in the Model View Options as you tried, but every view has its own MVO setting.
So you should:
1. Go to Document/Set Model View/Model View Options: set a custom fill display and store the desired settings as a new MVO combination
2. Go to the Layout
3. Select the drawing and right click on it -» Open Source View
4. Switch to the View Map in Navigator and open the selected view's settings dialog
5. In the View Settings/ General tab now you can select your custom MVO
The layout drawing needs to be refreshed.
I hope it helps,
Katalin Takacs
Thank you for the tip.
Yes, it worked out very well
Kyle
