2026-05-22
05:39 PM
2026-05-27
10:15 AM
Gordana Radonic
I mostly have a fix for proper MVO display for Doors and Windows. There is an error someplace in the Graphisoft system that returns the exact same value for Full, and Simplified with sash. Both return 6, but Simplified with sash should return 8 and full should return 6. The values are set correctly in their object DWS_MMVOSettings_USA.gsm but it is not transmitting properly.
You will need to select your translations for the old Detailed, Medium, and Simple. Below are the codes and the correct lookup. I translate to my needs rather than rewriting all the code at this point for the new options. If you put a line in your master script: !DWS_MVOSettings_USA then highlight and click on the </> icon to open the object, you can test various options and then look back at the parameter list to see the number that is set.
! iDWDet2D, MVODetlevel2D
WIN2D_1LIN = 1
WIN2D_2LIN = 2
WIN2D_2LINFRAMES = 3
WIN2D_GLASS1LIN_NOSASH = 4
WIN2D_GLASS1LIN_SASH_NOACC = 8
WIN2D_GLASS1LIN_SASH = 5
WIN2D_GLASS1LIN_REBATE = 6
WIN2D_GLASS2LIN_REBATE = 7
if P_Det_Level = "by MVO" then
MVO_2DDetail = 0
_bSuccess = LIBRARYGLOBAL("DWS_MVOSettings_USA", "iDoor2DDetlevel", MVO_2DDetail)
if _bSuccess > 0 then
if MVO_2DDetail = 11 then
Det_Level = "Detailed"
No_Trim = 0
endif
if MVO_2DDetail = 10 then
Det_Level = "Detailed" !my medium
No_Trim = 1
endif
if MVO_2DDetail = 9 or MVO_2DDetail = 1 then
Det_Level = "Simple"
No_Trim = 0
endif
else
No_Trim = 0
endif
endifif P_Det_Level = "by MVO" then
MVO_2DDetail = 0
_bSuccess = LIBRARYGLOBAL("DWS_MVOSettings_USA", "iWindow2DDetlevel", MVO_2DDetail)
if MVO_2DDetail = 6 then
No_Trim = 0
endif
if MVO_2DDetail = 8 then
No_Trim = 1
endif
if MVO_2DDetail = 1 then
No_Trim = 0
endif
else
No_Trim = 0
endif
endif
2026-05-26 09:02 PM
Hi @jp, based in this post I was wondering, have you managed to make the OpeningLines macro work? If so, can you shed some light on how? I got in touch with @vdentello last year about this problem and we still haven't found a solution. I'll leave the link below to the community post where we started the discussion, if you could check it out when you have the chance.
https://community.graphisoft.com/t5/GDL/Archicad-28-OpeningLines-Macro/m-p/670185#M7859
Thanks!
2026-05-26 09:41 PM
Hi Gabriel,
I was typing a reply to you in the app and then all my typing disappeared and I could not get it back. So here I go again. I have not tried to get the opening lines in 3d yet, but you can apply my process to get what you need. Your syntax is incorrect as you need to replace requestValue with the name of your local variable that will carry the value you get from this lookup.
success = LIBRARYGLOBAL ("DW_MVOSettings", "iDW3DLineOrient", requestValue)
Below are my lookups to get the plan settings of the opening lines
success = LIBRARYGLOBAL ("DWS_MVOSettings_USA", "penDoor2DOpLine", pen_mvo_arc)
success = LIBRARYGLOBAL ("DWS_MVOSettings_USA", "lineTypeDoor2DOpLine", LT_mvo_arc)
pen_mvo_arc and LT_mvo_arc are my local variables assigned to the lookup of the parameter in DWS_MVOSettings_USA. In your script, if you highlight DWS_MVOSettings_USA and then click on the </> icon in the top ribbon of the gdl editor, it will open this object and you can see all the parameter names to make sure you are looking up the correct one. You can even look at the interface script and preview it so you better figure out the parameters it is using.
I do not see a pen assignment for the 3d swing line, so It may use the same pen as the plan. There are two parameters for the linetypes however, iDWS3DOpeningSideOpLineType and iDWS3DOpeningSideOpLineType. The way the lines are drawn are a bit more complicated since it is based on a picture that is clicked. But there are only a few values for each so it's not too bad. The parameters to lookup are iDWS3DLineOrient and iDW3DArrowOrient I think. Once you open the object, you can get a lot of info.
I hope this helps!,
JP
Wednesday
- last edited
Wednesday
hi @jp,
Sorry about the delay in responding. This time I managed to work it out looking up some native objects (I actually did this before, but I guess I looking at the wrong spot). My problem was just with opening lines for furnitures (the MVO was working fine). Found the correspondent CALL in this kitchen macro and it worked kinda straight away.
So I guess that for doors e windows it should work just fine with the correspondent macro. The curious part is that the generic macro (OpeningLines) is very similar, but I never managed to make it work with the new library (AC 28+).
Thanks for the help!
