GDL
3D Text to have no pen outline
JGoode
Hello,
Is it possible to get my 3D text to not show a pen outline in the 3D view?
Thanks
ArchiCAD 23
Windows 10
3 REPLIES 3
A_ Smith
AC22, win10 works
pen 20 !red
material 99 ! any material
group "one"
DEFINE STYLE "aa" "New York", 3, 7, 0
SET STYLE "aa"
TEXT 0.005, 0, " " !empty
endgroup
group "one1"
material 99
TEXT 0.005, 0, "3D Textnow without line?.."
endgroup
placegroup addgroup{2}("one","one1",0,0,0,1)	!if last digit is '0' (not 1) line will appear
last image (with red lines) - changed 1 to 0.
though idk why it didn't work on the exact same group - had to join to empty 3D text...
AC 22, 24 | Win 10
Peter Baksa
The last parameter is operationStatus: status control of the operation.
operationStatus = j1 + 2*j2, where each j can be 0 or 1.
j1: generated new edges will be invisible.
If you add the same to something, there are no new edges.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
JaseBee
Seems they've added a function to simplify this process now...
From GDL reference guide...
"CREATEGROUPWITHMATERIAL
CREATEGROUPWITHMATERIAL (g_expr, repl_directive, pen, material)
Returns a group that is created by replacing all pens and/or materials in group g_expr.
g_expr: group expression identifying the base group.
repl_directive:
repl_directive = j1 + 2*j2 + 4*j3 + 8*j4, where each j can be 0 or 1.
j1: replace pen,
j2: replace material,
j4: make edges invisible.
pen: replacement pen index.
material: replacement material index."
AC 24 5004 AUS
iMac OSX (10.13.6) 4.2ghz i7
8gb ram/8gb vram
