Anyone interested in a quick job?
Hi
I have a very simple request that as yet has not become a priority for GS but is utmost for any GDL developers trying to create library parts consistent with the model view options (although gs seem to be moving toward it).
I simply need a gdl REQUEST that will return the current model view option name i.e. MVO Name.
I have source code for a parallel api 'Project Path' which returns the project name and just needs the appropriate code changed and recompiled (for 10). Any takers?
Regards
Mark
I have not reviewed the latest GDL dev kit, but AFAIK, MVO info (and most other model info that is otherwise accessible by the general API sdk) cannot be accessed via a GDL add-on. If that's still the case, then this probably isn't a quick job since some wizardry would be required...
Karl
