2024-04-05
08:16 AM
2024-09-26
01:06 PM
Doreena Deng
Is anyone else experiencing extremely slow speeds and lags with the new GDL tool in Archicad 27?
I am experiencing this when I have 2 object tabs open and I try and write in any of the scripting windows. Copying and pasting script from one object to the other is probably the biggest lag that happens. I am using Windows 11, not sure if this is an OS problem, hardware problem or simply a bug in Archicad 27.
Shaun.
2024-04-05 08:44 AM
Hey Shaun,
Yep - massively slow and gets slower the more objects you have open. I have found that if you are using a widescreen monitor - resize Archicad down smaller so it is like 1024 x 768 or something and the new GDL editor will be quite a bit faster.
Hope this helps until we get a fix from GS.
Danny
2024-04-05 08:59 AM
Sounds like they aren't going to fix it. I got the whole, "we do not support GDL related issues" from Central Innovation. They claim this is what Graphisoft said. So I am not overly optimistic we will have a fix for this soon.
2024-04-05 09:02 AM
It is not a GDL coding issue - I can understand they may not support that.
It is a program issue if the editor is not behaving as it should.
2024-04-05 09:06 AM
Thats what I said to them. But feels like talking to a brick wall. They really know how to P*** their customers off.
2024-04-05 09:15 AM
Id be happy to just be able to turn the new editor off and return to the plain old text editor.
2024-05-07 10:06 AM
Same issue here. Tried following steps without effect:
The lagging in the typing is really annoying as it stops the "flow" constantly, especially when you're fixing typing errors (backspace "crosses" other key strokes...).
I also noticed that the menu bar at the very top is blinking at every key stroke...
(I recorded the sound of me typing - emphasizes the lag... - apologies for "breathing" sounds 😅)
2024-05-23 06:41 PM
Refer to this topic: https://community.graphisoft.com/t5/GDL/GDL-editor-AC27-far-from-being-usable/td-p/581752
maybe we should ask for merging the topics...as more people started to feel the pain with the new editor 😛
the only one thing is faster than in the old one: search an replace... 😛
The first thing I would make the syntax plug switch which is absent...the syntax highlight is the resource hog in this implementation.
2024-05-24 08:58 AM
how are you sure it is the syntax plug?
When typing comments, the syntax plug should not be doing any intensive work? But even then there is lag...
2024-05-24 03:15 PM
Not 100% sure, but when You open a really large file.... the editor kicks in without syntax preview, and the syntax kicks in after looong seconds.
