Yasemin Afacan
Archicad vs. Autocad/Architectural Desktop
Hi everyone.
I am a new comer to this forum. I am a Ph.D. candidate and instructor of FA 131 Technical Drawing and Lettering I in the Department of Interior Architecture and Environmental Design at Bilkent University, Ankara, Turkey.
I got acquainted with this forum when working on my Ph.D. thesis. I have read all AC vs. Revit and now I have questions related AC' programming language. In AutoCad/Architectural Desktop I can use Visual Basic to create some add-in and macros. And my question is that in ArchiCad GDL has same role and function compared to VB in AutoCad/Architectural Desktop? Is it possible to make all desired add-in and macros with GDL?
If not so, what language should I learn and use?
Yasemin Afacan
5 Replies 5
Rafal SLEK
In AC You got two ways to make what You described:
- GDL is for making objects used in AC, it something like programming in Basic and it is open for everyone,
- Add-on programming with C+. Also for everyone (and free) but you need more detailed information how to do it. In this way you could make plugin working inside Archicad.
regards
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Tahoe/Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/
//MSI AMD Ryzen AI 9/2.5GHz/32GB/Nvidia RTX 5070 Ti/Windows 11 Pro
//ArchiCAD Collaborate
Yasemin Afacan
Thank you Rafal.
You can download the Archicad Developer Kit from:
http://www.graphisoft.com/support/developer/
Yasemin Afacan
Thanks Laszlo Nagy.
As far as I understand this developer kit is free, and to able to use it I should learn C++.
Yes, correct.
If you download it, you will find all relevant information in it, I suppose (program requirements, condtions etc.)
