Aurasphere
BUG: Legacy Layout listings broken
I realise re: deprecation etc that it may not get addressed but Im clearly putting here...not as a feature request or anything but simply to fix what has been broken
calculations no longer seem to be processed any longer and if you run any of the legacy/component listings etc, what use to work a couple of versions ago, no longer does
eg
The new property manager etc has no way to write to files etc
Thats why the legacy is so important and more so, it deserves a revamp and finish the whole package
  • WYWSWIG graphic editor for layouts
  • Ability to attach multiple components/descriptors directly to elements/objects and allow property objects for common recipes
The legacy feature does so much more for professional office collaboration in eg project builders where bim <> estimating is a crucial link.
Cheers
Mark Wesse
AC26 | Win10 | Since v6.5r
Architerion - Architectural Systems Developer
Aurasphere - Acoustics
Building Biology - Human Compatible Architecture
"--- Every time...do it better ---"
11 Replies 11
Peter Baksa
In the case of "Components/Keys (long)" the formatting is fine, it is the referenced field that is not correct.
Instead
Format "^Total[7]:8.2 #unit[7]"
Format "^Total[5]:8.2 #unit[5]"
works as I'd expect. Adding an expression is also ok:
Format "^(Total[5]+3):8.2 #unit[5]"
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Peter Baksa
The .lis file contains the order of the data:
	7	3003	0	00000019
		3004	0	00000019
		3005	0	00000019
		3001	0	00000019
		3002	0	00000019
		3006	0	00000019
		3007	0	00000019
means the fifth field is 3002: Component quantity and the seventh field is 3007: Component reference unit
Péter Baksa
