Call macro and parameters all
I try to understand macros. Some elements from Graphisoft include this part of the script.
call "macro",
parameters all alpha = alpha
Why do I need "alpha = alpha", when the name of the variable is the same in the caller object and in the macro?
Thanks for your support.
4 Replies 4
Dominic Wyss
Hi Manuel
Maybe the value of alpha was modified in the caller script. So its actual value has to be passed with
alpha = alpha
In this situation the first "alpha" is a variable and the second "alpha" is the name of the parameter in the called macro.
if you don't do that the original value will be passed to the macro:
!parameter list:
!alpha = 90
!masterscript:
alpha = 270
!2d-script:
call "macroname" parameters all ! <= alpha in macro = 90
call "macroname" parameters all alpha = alpha ! <= alpha in macro = 270
HTH Dominic
AC27 CHE - macOS Ventura M1
Hi Dominic,
Can I use CALL from macro parameter become to other parameter in call object?
Example: I want to call Resize_A_B macro (A, B parameter for resize) but in my object I want to resize difference parameters (e.g. width & height parameter)
Thanks in advance
Peter Baksa
No, a macro can only change parameters (parameter script, hotspots) that the placeable object has, GDL doesn't have the concept of passing parameters by reference.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Peter Baksa
!parameter list:
!alpha = 90
!masterscript:
alpha = 270
!2d-script:
That's not the case, both calls will give alpha = 270 to the macro.
Writing any <param> = <param> after all is just an emphasis.
It has to be written only in case when the placeable object doesn't have a parameter that the macro has (when it's only a variable in the caller object).
Péter Baksa
