Nader Belal
Mentor
Question about Arrays & Subroutines
Hi there,
I would like to ask why the creation of arrays in a sub-routine in Parameter script as in the following example is generating an error ("Incompatible array dimensions")
some script
if condition is met then
	gosub 001
	_tempArray = _origArray		!<--both arrays are one dimension
endif
some script
end
001:
dim _tempArray
return
1 Solution
Jochen Suehlo
In my experience it happens, that arrays defined in a subroutine where not recognized in parts of scripts that are above the subroutine (in the text order).
Example:
gosub 100
_newVALUE = _tempArray[1]
end
100:
dim _tempArray[]
_tempArray[1] = 2
return
But if you change this into this, it works:
gosub 100
gosub 200
end
100:
dim _tempArray[]
_tempArray[1] = 2
return
200:
return
This is a weird thing, but I think, it is a bug.
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
Go to post
4 Replies 4
Jochen Suehlo
Example:
gosub 100
end
100:
dim _tempArray[]
_tempArray[1] = 2
return
gosub 100
gosub 200
end
100:
dim _tempArray[]
_tempArray[1] = 2
return
200:
return
Nader Belal
Mentor
@Joachim Suehlo
Thank you a lot.
leceta
From the book GDL Handbook, by Andrew Watson, 3.5.Scope, pages 36-37
Array variables have some interesting characteristics when it comes to scope. You must define an array before you can use it, which stands to reason. You can define an array variable in a sub-routine (we’ll discuss sub-routines later) but it’s best to define arrays in the main script. If you define an array variable in a sub-routine and then try to use it in the main script, error messages will pop up when you try to save the object.
and later:
The variable must be declared at a point in the script that comes both physically and logically ahead of the point at which it is used.
Peter Baksa
This isn't a bug, it's a limitation. The order of statements can depend on parameters, it is only known at run-time. Variables mustn't change their types during run, the best the interpreter can do is check the code line-by-line (there are simple cases when the order of execution is evident, but it can get complicated very easily). If it didn't do this check, it would be possible to get error messages only by some parameter states, which would make them very hard to detect and understand.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
