arad
Cannot Convert HSF to GSM with embedded image
I’m trying to create a GSM with embedded images from HSF using LP_XMLConverter.
However, when I run the converter, I get the following error and the conversion fails:
error: Error in image section ; Invalid Image File - could not open for reading
The image is just a normal PNG file.
What could be causing this, and how can I fix it so the conversion succeeds?
Jochen Suehlo
I don't think hsf2l can embed new graphics.
At least, it doesn't work for me.
I always use
“pathOfLP_XMLConverterExecuteable” x2l -img “imageFolderPath” ‘xmlFolderPath’ “binaryFolderPath”
which works very well.
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
arad
I tried it with x2l and it worked.
However, when I tested it previously, I believe image embedding also worked with HSF.
The issue with HSF has not been resolved yet, but for now I have been able to avoid the situation where embedding is not possible.
Thank you very much.
