Podolsky
Ace
Cannot figure out how to get wall radius for label
I need to script a label, that would know radius (also coordinates of radius centre) of the wall. I looked how window knows about it - for that there is special global variable WIDO_ORIG_DIST. But wall's global variables do not have any information about it. Any ideas? Or it's just impossible?
21 Replies 21
Thanks Dominic.
I see that you properly defined the dictionary. No errors.
The test I did gave me some errors probably due to the lack of dict definition.
Peter Baksa
You can use .referenceLine2D.contour.edges.type to determine whether it is an arc or line.
Multiple edges can exist on polygonal-shape walls.
Dominic wrote:
Here's my quick & dirty solution for wall radius:
if haskey(LABEL_ASSOC_ELEM_GEOMETRY.referenceLine2D.contour.edges[1].ArcAngle) then
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
