2020-07-02
12:16 AM
2022-09-26
10:50 PM
Daniel Kassai
Solved! Go to Solution.
2020-08-17 05:36 AM
Carlos wrote:
Good day.
I would like to know how to add anchor plates, anchor fist, and all related to curtain wall stack joint on my model.
I can easily create my curtain wall but I do not how to integrate it to my slab.
thanks
2020-08-17 02:59 PM
Mjules wrote:Are you particularly working with Curtain Wall anchoring? If so, maybe I can give you a hand...with a direct contact.
Nagy,
I would appreciate if you could share with us a video demonstration about your test using GDL.
Carlos wrote:
Can you give some example of how I can achive that... I'm very new on this.![]()
Thanks for all you support
2020-08-17 03:06 PM
Mjules wrote:
Hi Carlos,
Did you realize both the 3D and 2D details of this curtain wall with ArchiCAD?
2020-08-17 03:37 PM
Carlos wrote:
Mjules wrote:
Hi Carlos,
No, I don't. But I got something very similar in 3D.
2020-08-17 04:34 PM
Carlos wrote:
Mjules wrote:
Hi Carlos,
2020-08-17 05:55 PM
Mjules wrote:
Thanks for replying!
I used to copy and paste the wall section details with all the related specifications into the ArchiCAD’s section window and then draw the 3D details using the morph tool.
This technique should give you a better result in terms of structural element connections. As you can see in your 3D details, there are some connection issues with the ArchiCAD’s curtain wall frames when using the curtain wall tool of ArchiCAD.
Carlos wrote:
Mjules wrote:
Hi Carlos,
No, I don't. But I got something very similar on 3D.
2020-08-18 03:24 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
