leilei
How to set filling symbols for different materials with project{3}?
HI,I'm cutting the model with cutplan, and now I want to make plane projection for filling symbols of cutting surfaces of different materials. I don't know how to implement the project command. Can anyone help me.
Lingwisyer
Guru
As far as I know, you can only get a single fill by using Project2{3} unless you stick with the vector fills which, if containing transparency, turn black... You will not be able to see cut surfaces using Cutplane as you will not actually be cutting anything and see only the faces created by your Cutplane.
See this tips & tricks page.
Ling.
