Bregt
Display two types of dooropening lines
I'm looking for a way to alter the opening lines of a double door separately. In the 'door selection setting' it's only possible to override both opening lines of the door. I'm slightly familiar with GDL code but I can't manage change the 'door selection setting' to two separate parameters, one for each doorpanel. Is there a way to achieve this?
 Schermafbeelding 2024-11-05 om 14.37.50.pngSchermafbeelding 2024-11-05 om 14.38.27.png
Operating system used: Mac Intel-based
Setup info provided by author
It will not be possible in the object settings unless there is already a second line type parameter for the second door.
But I am sure you would have seen it, if it was there.
I don't use these doors so I am not familiar with them, but I would be very surprised if it was there.
The only solution would be a GDL one, but it is not recommended to alter Graphisoft objects, because every time there is an update, you will have to re-do the change.
If you are wanting to investigate  a GDL solution, I will move this post to the GDL forum.
Bregt
Hi Barry, there is indeed no second parameter for the second door.
You may move the post to the GDL forum. Thanks!
