rudl
Easy gdl mesh
Easy mesh:
! No more VERT EDGE PGON ! (because its a bit of a pain)
just a vertex array
and a face array with vert indices
Face direction should be automatic with the order of vertices, Edges are automatic
Needs more testing, may add some more features.
! Geometry stored in vert and pgon arrays only Example: Pyramid
! Important order of vertices in Pgon determine Normal / Face direction
! --- SETUP VARIABLES ---
dim points_s[][3]	!points start
dim edges_pi[][2]	!edges point index
dim faces_pi[][]	!faces point index
dim ppf[]			!points per face
! --- POPULATE ---
points_s[1][1] = -1 : points_s[1][2] = -1 : points_s[1][3] = 0	! base
points_s[2][1] =  1 : points_s[2][2] = -1 : points_s[2][3] = 0
points_s[3][1] =  1 : points_s[3][2] =  1 : points_s[3][3] = 0
points_s[4][1] = -1 : points_s[4][2] =  1 : points_s[4][3] = 0
points_s[5][1] =  0 : points_s[5][2] =  0 : points_s[5][3] = 2  	! apex
ppf[1] = 4 : faces_pi[1][1] = 1 : faces_pi[1][2] = 4 : faces_pi[1][3] = 3 : faces_pi[1][4] = 2 	! base (quad)
ppf[2] = 3 : faces_pi[2][1] = 1 : faces_pi[2][2] = 2 : faces_pi[2][3] = 5
ppf[3] = 3 : faces_pi[3][1] = 2 : faces_pi[3][2] = 3 : faces_pi[3][3] = 5
ppf[4] = 3 : faces_pi[4][1] = 3 : faces_pi[4][2] = 4 : faces_pi[4][3] = 5
ppf[5] = 3 : faces_pi[5][1] = 4 : faces_pi[5][2] = 1 : faces_pi[5][3] = 5
nPoints = 5 		! this should be known does not make sense to calc! optional with VARDIM1
nFaces = 5 		! this should be known does not make sense to calc! optional with VARDIM1
! DO THE MAGIC THING:
! --- Point index for edges --- edges_pi[][2] for use in EDGE
x=0	! the counter is important!
FOR i=1 TO nFaces
	FOR j=1 TO ppf[i]
		x = x+1
		IF j < ppf[i] THEN
			edges_pi[x][1]=faces_pi[i][j]
			edges_pi[x][2]=faces_pi[i][j+1]
		ELSE
			edges_pi[x][1]=faces_pi[i][j] !connect last point of face with first
			edges_pi[x][2]=faces_pi[i][1]
		ENDIF
	NEXT j
NEXT i
lengthedge = VARDIM1 (edges_pi) ! total edges with duplicates should be nEDGE
! --- Create edge index --- edges[] for use in PGON
! There is some kind of "sorting" through to make the double edge indices negative
! could be optimised for larger meshes though
DIM edges[]
negcount = 0
FOR i = 1 TO lengthedge
	u = edges_pi[i][1]
	v = edges_pi[i][2]
	edges[i]=i-negcount
		FOR j = 1 To i
			IF edges_pi[j][1]=v AND edges_pi[j][2] = u THEN
				edges[i]= edges[j]*(-1)
				negcount = negcount+1
			ENDIF
		NEXT J
NEXT i
! BUILDING THE MESH:
!PUT EVERYTHING TOGETHER
BASE
FOR i = 1 TO nPoints
	VERT points_s[i][1],points_s[i][2],points_s[i][3]
NEXT i
	IF edges[i]>=1 THEN
		EDGE edges_pi[i][1], edges_pi[i][2],-1,-1,0
	ENDIF
NEXT i
PUT edges
FOR i = 1 TO nFaces
	PGON ppf[i],0,0,GET(ppf[i])
NEXT i
BODY -1
! DEBUG:
!PRINT edges_pi
!PRINT edges
12 Replies 12
Thanks for showing the method, but I am not sure I understand the purpose.
You did use VERT EDGE PGON, just in a loop.
And wouldn't it be easier to use the PYRAMID command?
rudl
In the end of course i used Vert edge and pgons etc.
The pyramid is just a simple example  I'm thinking about much more complex things. Its more about how it is stored
Its way easier if you have indices than the order of creation
especially if you want to create something parametric where the number of vertices edges pgons is not known
rudl
Not a pyramid:
In conjunction with a blender script (I did us chatgpt for that)
import bpy
# Output file path
output_file = "C:/Users/potato/mesh_data.txt"  # <-- change this
with open(output_file, 'w') as f:
    vertex_count = 1
    face_count = 1
    for obj in bpy.context.selected_objects:  # or bpy.data.objects for all
        if obj.type != 'MESH':
            continue
        mesh = obj.data
        #f.write(f"// Object: {obj.name}\n\n")
        # Write vertices
        for v in mesh.vertices:
            f.write(f"points_s[{vertex_count}][1] = {v.co.x}\n")
            f.write(f"points_s[{vertex_count}][2] = {v.co.y}\n")
            f.write(f"points_s[{vertex_count}][3] = {v.co.z}\n")
            vertex_count += 1
        f.write("\n")
        # Write faces
        for p in mesh.polygons:
            # Ensure we only handle triangles or quads (can expand if needed)
            verts = p.vertices
            for i in range(len(verts)):
                f.write(f"faces_pi[{face_count}][{i+1}] = {verts[i]+1}\n")  # +1 for 1-based indexing
            face_count += 1
        f.write("\n")
print(f"Mesh data exported to {output_file}")
rudl
Was a little slow but it should be much faster now.
Sorted the edges before checking for the "oposite edge" otherwise it loops through the whole array for every edge. ^^
dim po_s[][3]	!points start
dim f_pi[][]	!faces point index
! --- POPULATE ---
po_s[1][1] = 0.03838 : po_s[1][2] = -0.02232 : po_s[1][3] = 0.08784
po_s[2][1] = -0.01273 : po_s[2][2] = 0.01263 : po_s[2][3] = 0.14178
po_s[3][1] = -0.07195 : po_s[3][2] = -0.01823 : po_s[3][3] = 0.08623
po_s[4][1] = 0.0298 : po_s[4][2] = -0.00251 : po_s[4][3] = 0.09868
po_s[243][1] = 0.0156 : po_s[243][2] = -0.03653 : po_s[243][3] = -0.0
po_s[244][1] = -0.04308 : po_s[244][2] = 0.03277 : po_s[244][3] = 0.1129
po_s[245][1] = -0.04553 : po_s[245][2] = 0.0671 : po_s[245][3] = 0.1219
f_pi[1][1]=5:f_pi[1][2]=141:f_pi[1][3]=28 : f_pi[2][1]=122:f_pi[2][2]=133:f_pi[2][3]=148 : f_pi[3][1]=147:f_pi[3][2]=11:f_pi[3][3]=111
f_pi[4][1]=134:f_pi[4][2]=52:f_pi[4][3]=124 : f_pi[5][1]=5:f_pi[5][2]=12:f_pi[5][3]=141 : f_pi[6][1]=28:f_pi[6][2]=141:f_pi[6][3]=31
f_pi[7][1]=21:f_pi[7][2]=155:f_pi[7][3]=163 : f_pi[8][1]=194:f_pi[8][2]=134:f_pi[8][3]=124 : f_pi[9][1]=52:f_pi[9][2]=134:f_pi[9][3]=40
f_pi[478][1]=230:f_pi[478][2]=229:f_pi[478][3]=238 : f_pi[479][1]=229:f_pi[479][2]=227:f_pi[479][3]=222 : f_pi[480][1]=222:f_pi[480][2]=224:f_pi[480][3]=229
f_pi[481][1]=223:f_pi[481][2]=226:f_pi[481][3]=225 : f_pi[482][1]=226:f_pi[482][2]=233:f_pi[482][3]=225 : f_pi[483][1]=243:f_pi[483][2]=238:f_pi[483][3]=240
f_pi[484][1]=240:f_pi[484][2]=232:f_pi[484][3]=243 : f_pi[485][1]=233:f_pi[485][2]=243:f_pi[485][3]=235 : f_pi[486][1]=232:f_pi[486][2]=235:f_pi[486][3]=243
nPoints = 245 		! this should be known does not make sense to calc! optional with VARDIM1
nFaces = 486 		! this should be known does not make sense to calc! optional with VARDIM1
FOR i=1 TO nFaces
	ppf[i]=3
NEXT i
DIM edges_so[][]
FOR i=1 TO nFaces
	FOR j=1 TO ppf[i]
		x = x+1
		IF j < ppf[i] THEN
			edges_pi[x][1]=f_pi[i][j]
			edges_pi[x][2]=f_pi[i][j+1]
		ELSE
			edges_pi[x][1]=f_pi[i][j] !connect last point of face with first
			edges_pi[x][2]=f_pi[i][1]
		ENDIF
		edges_so[edges_pi[x][1]][1] = edges_so[edges_pi[x][1]][1]+1 !self+1
		edges_so[edges_pi[x][1]][edges_so[edges_pi[x][1]][1]+1] = x
	NEXT j
NEXT i
nEdges = VARDIM1 (edges_pi) ! total edges with duplicates
negcount = 0
DIM edges[]
FOR i = 1 TO nEdges
	!edges_pi[i][2]
	IF edges[i] < 0 THEN
	negcount = negcount +1
	ELSE
	tempi = i-negcount
	FOR j = 2 TO edges_so[edges_pi[i][2]][1]+1
		IF edges_pi[i][1] = edges_pi[edges_so[edges_pi[i][2]][j]][2] THEN
			!"PRINT "gefunden"
			edges[i] = tempi
			edges[edges_so[edges_pi[i][2]][j]] = -tempi
		ENDIF
	NEXT j
	ENDIF
NEXT i
BASE
	VERT po_s[i][1],po_s[i][2],po_s[i][3]
NEXT i
FOR i = 1 TO nEdges
	IF edges[i]>=1 THEN
	ENDIF
NEXT i
PUT edges
FOR i = 1 TO nFaces
NEXT i
BODY -1
Full res bunny example:
69664 Faces, 34834 Points
Screenshot 2025-10-25 232153.pngScreenshot 2025-10-25 234639.pngScreenshot 2025-10-25 234900.png
rudl
"Hair"
Face - Normals added
This is all very impressive, I like it.
But where are you getting the x,y,z co-ordinates for the model.
Doesn't it mean that someone has modelled it up already?
I do quite a few basins and baths based on converted RVT, OBJ, SKP, 3DS, etc, objects.
I would love to reduce there 50000+ lines of code down to something much simpler like this.
rudl
*) Edge Angles
*) Edge Visibility/sharp edges based on edge angle.
rudl
Face and Vertex numbering, Point normals etc
Davor P
Might be useful if you are storing points and faces in a text file and read them with gdl.
www.vktrs.co
