jshuether
GDL: line elimination in tube and sweep
I've tried scripting the same tubular shape using "tube" and "sweep."  Both results are not completely as desired due to the lines appearing in 3D. Is there anyway to eliminate these lines?
resol 32
sweep 2,36,0,1,1+2+16+32,
0,0,901,
1.5",360,4001,
0, 0,0,
-0.002423906727007, 0, 0.01985728285465,
-0.009553281085534, 0, 0.03854843107325,
-0.0209694449781, 0, 0.05497579246977,
-0.03600197523167, 0, 0.0681746573698,
-0.05376807472403, 0, 0.07736991208629,
-0.07322441533673, 0, 0.08202155807843,
-0.09322840821666, 0, 0.08185642378919,
-0.112605303202, 0, 0.07688420685914,
-0.1304973420971, 0, 0.07227206087591,
-0.1489734891216, 0, 0.0721019505473,
-0.1669474159616, 0, 0.07638387772413,
-0.1833623229707, 0, 0.08486608110985,
-0.1972530750355, 0, 0.0970498388827,
-0.2078029479089, 0, 0.1122187916729,
-0.2143916485396, 0, 0.1294810618131,
-0.2166317859831, 0, 0.1478216924083,
-0.2166317859831, 0, 0.1841500001531,
-0.2132425096615, 0, 0.2075611583201,
-0.2033529894545, 0, 0.2290499207502,
-0.1877752984492, 0, 0.246851748287,
-0.1677885910799, 0, 0.259504852619,
-0.1450340659906, 0, 0.2659702303082,
-0.1213801998159, 0,0.2657169800459,
-0.09876931814137, 0, 0.2587658973528,
-0.07905810239333, 0, 0.2456877669651,
-0.01253816267045, 0, 0.1862092986141,
0.01399616622115, 0, 0.1686041230921,
0.04443389155222, 0, 0.1592468963899,
0.07627563447966, 0,0.1589059825753,
0.1069067259461, 0,0.1676093756184,
0.1338119089432, 0,0.1846424006807,
0.1547818776041, 0,0.2086063992879,
0.1680946932674, 0, 0.2375335794824,
0.1726571806235, 0, 0.2690486000918,
0.1726571806235, 0, 0.2844011163528
addy 2'
rotx 90
tube 2,38,1+2+16+32,
0 , 0 , 901,
1.5", 360, 4001,
0, -1,0, 0,
0, 0,0, 0,
-0.002423906727007, 0.01985728285465,0, 0,
-0.009553281085534, 0.03854843107325,0, 0,
-0.0209694449781, 0.05497579246977,0, 0,
-0.03600197523167, 0.0681746573698,0, 0,
-0.05376807472403, 0.07736991208629,0, 0,
-0.07322441533673, 0.08202155807843,0, 0,
-0.09322840821666, 0.08185642378919,0, 0,
-0.112605303202, 0.07688420685914,0, 0,
-0.1304973420971, 0.07227206087591,0, 0,
-0.1489734891216, 0.0721019505473,0, 0,
-0.1669474159616, 0.07638387772413,0, 0,
-0.1833623229707, 0.08486608110985,0, 0,
-0.1972530750355, 0.0970498388827,0, 0,
-0.2078029479089, 0.1122187916729,0, 0,
-0.2143916485396, 0.1294810618131,0, 0,
-0.2166317859831, 0.1478216924083,0, 0,
-0.2166317859831, 0.1841500001531,0, 0,
-0.2132425096615, 0.2075611583201,0, 0,
-0.2033529894545, 0.2290499207502,0, 0,
-0.1877752984492, 0.246851748287,0, 0,
-0.1677885910799, 0.259504852619,0, 0,
-0.1450340659906, 0.2659702303082,0, 0,
-0.1213801998159, 0.2657169800459,0, 0,
-0.09876931814137, 0.2587658973528,0, 0,
-0.07905810239333, 0.2456877669651,0, 0,
-0.01253816267045, 0.1862092986141,0, 0,
0.01399616622115, 0.1686041230921,0, 0,
0.04443389155222, 0.1592468963899,0, 0,
0.07627563447966, 0.1589059825753,0, 0,
0.1069067259461, 0.1676093756184,0, 0,
0.1338119089432, 0.1846424006807,0, 0,
0.1547818776041, 0.2086063992879,0, 0,
0.1680946932674, 0.2375335794824,0, 0,
0.1726571806235, 0.2690486000918,0, 0,
0.1726571806235, 0.2844011163528,0, 0,
0.1726571806235, 0.2944486000918,0, 0
ArchiCAD 25
Windows 10
David Maudlin
jshuether:
When using the Tube command, the only way I found to eliminate those "creases" is to increase the number of path points, so the path is smoother (higher resolution). Try adding additional path points between the creases.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
A_ Smith
create group for that shape and add it to itself, at least in ac24 it works
group "abc"
sweep 2,36,0,1,1+2+16+32, 0,0,901, 1.5",360,4001,   0, 0,0, -0.002423906727007, 0, 0.01985728285465, -0.009553281085534, 0, 0.03854843107325, -0.0209694449781, 0, 0.05497579246977, -0.03600197523167, 0, 0.0681746573698, -0.05376807472403, 0, 0.07736991208629,  -0.07322441533673, 0, 0.08202155807843, -0.09322840821666, 0, 0.08185642378919, -0.112605303202, 0, 0.07688420685914, -0.1304973420971, 0, 0.07227206087591, -0.1489734891216, 0, 0.0721019505473, -0.1669474159616, 0, 0.07638387772413,  -0.1833623229707, 0, 0.08486608110985, -0.1972530750355, 0, 0.0970498388827, -0.2078029479089, 0, 0.1122187916729, -0.2143916485396, 0, 0.1294810618131, -0.2166317859831, 0, 0.1478216924083, -0.2166317859831, 0, 0.1841500001531,  -0.2132425096615, 0, 0.2075611583201, -0.2033529894545, 0, 0.2290499207502, -0.1877752984492, 0, 0.246851748287, -0.1677885910799, 0, 0.259504852619, -0.1450340659906, 0, 0.2659702303082, -0.1213801998159, 0,0.2657169800459,  -0.09876931814137, 0, 0.2587658973528, -0.07905810239333, 0, 0.2456877669651, -0.01253816267045, 0, 0.1862092986141, 0.01399616622115, 0, 0.1686041230921, 0.04443389155222, 0, 0.1592468963899, 0.07627563447966, 0,0.1589059825753,  0.1069067259461, 0,0.1676093756184, 0.1338119089432, 0,0.1846424006807, 0.1547818776041, 0,0.2086063992879, 0.1680946932674, 0, 0.2375335794824, 0.1726571806235, 0, 0.2690486000918, 0.1726571806235, 0, 0.2844011163528
endgroup
placegroup addgroup{3} ("abc", "abc", 0,0,0,1)
AC 22, 24 | Win 10
