GDL
GSM extension file
Martin Jules
Mentor
Is there a new way or method to read imported .gsm exension files in Archicad 25?
Martin Luther Jules
AC 10-28 (Full)
Asus | 64 GB RAM | Windows 11
14 REPLIES 14
@Nader Belal It's about a bug. You can take a look at the Peter Baksa's answer regarding this post.
Martin Luther Jules
AC 10-28 (Full)
@ Peter Baksa Great! I will try modifying the incorrect syntax. Meanwhile, try to fix this bug as soon as possible since the GDL language is the Archicad's main signature.
Martin Luther Jules
AC 10-28 (Full)
@runxel It seems your proposal is relevant. It's also possible to add the folder which has the .gsm files in the Library Manager. With a .pla then we can open that with "Extract elements to a folder" and than use those folders with the other Archicad projects.
Martin Luther Jules
AC 10-28 (Full)
@Peter Baksa The issue still persists!
Martin Luther Jules
AC 10-28 (Full)
Hi Martin,
I don't have any influence on when bugs will be fixed. Please contact support to let them know abou the urgency.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
