Lingwisyer
Guru
Global Modification
Hi all,
Is there someway to write back to Globals?
Ling.
1 Solution
Lingwisyer
Guru
WIDO_SILL is apparently a global parameter instead of a standard parameter like A / B / ZZYZX.
I found a modifiable version of it in ac_wido_sill which writes back to WIDO_SILL. Though this is from wall face rather than core...
Ling.
Go to post
5 Replies 5
Not with GDL that I know of.
What GLOBAL are you trying to alter?
I am sure you could control them with an add-on or of course they are just standard Archicad settings which you can change.
Lingwisyer
Guru
Ling.
Peter Baksa
Hi Lingwisyer,
no, globals are one-way communication from Archicad to GDL. Technically it's allowed to change them, so your code and called macros see the changed value, but AC doesn't read it back.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Lingwisyer
Guru
Any reason WIDO_SILL is a Global rather than a standard parameter? Or is there some other parameter that I am missing that is Reveal to Wall Core?
Ling.
Peter Baksa
Historic reasons and keeping backwards compatibility.
You can use ac_wido_sill. The distance from wall face to core can be calculated using WALL_SKINS_PARAMS.
Péter Baksa
