matleonii
Help with text orientation
Hello everyone! I'm new to GDL and i'm working on a simple object that consist in a 2D symbol.
The idea is to have a circle with a letter in it. I'd love to make the letter always horizontal, but always inside the circle. I guess I should move the rotation point to so the letter rotates on its center, and not in the origin (0,0), but I just could not manage to do so. Is there a way to do this? any help would be awesome!
PS: on the image the blue symbol is the one with no text orientation rule, so you see the text upside down. The red one is with the always horizontal rule, and you see that the object rotates but the letter stays.
This is the code I used for the red one:
DEFINE STYLE "estilo" Arial, txtsize, 7, 0
STYLE estilo
! Text Rotation - Readable / Always Horizontal / Align with Symbol
r = request ("View_Rotangle", "", _angleViewRot)
! Actual rotation of the 2D symbol:
_totalRotate	= (SYMB_ROTANGLE + _angleViewRot) MOD 360
! Count the number of transformations of the
! coordinate system in different cases
_nTrans = 0
if iTypeTextRotation = 2 then					! Readable
    if (_totalRotate > (90 + EPS) & _totalRotate < (270 + EPS)) then
        rot2 180
        _nTrans = _nTrans + 1
    endif
else
    if iTypeTextRotation = 1 then				! Horizontal
        rot2 _totalRotate * (SYMB_MIRRORED - not(SYMB_MIRRORED))
    endif
endif
! Text
TEXT2 -0.035,0.04, txt
! Delete transformation after Text Rotation
del _nTrans
1 Solution
matleonii
Found it!
I was testing some with the codes and found a solution.
changed the text part so that the origin would rotate with the object and the "unrotate" for the text to get on the right position.
ROT2 -SYMB_ROTANGLE
ADD2 0, 0.1
ROT2 SYMB_ROTANGLE
TEXT2 0 ,0, txt
DEL 1
Go to post
4 Replies 4
Lingwisyer
Guru
Use Add2 for your transformation before your Text2 command, then set your text to [0, 0]?
You might also need to use a Style command to set your text anchor to center.
ADD2 -0.035, 0.04
TEXT2 0 ,0, txt
DEL 1
Ling.
matleonii
ADD2 -0.035, 0.04
TEXT2 0 ,0, txt
DEL 1
Ling.
Thanks for your reply! But it did not work. the issue kept the same.
matleonii
Found it!
ROT2 -SYMB_ROTANGLE
ADD2 0, 0.1
ROT2 SYMB_ROTANGLE
TEXT2 0 ,0, txt
DEL 1
Lingwisyer
Guru
Works fine for me. I guess I simplified my explanation too much for you as the code line I wrote there is not a straight substitution as you did not provide the full code.
See my test object enc.
Ling.
