GDL
SOLVED!
How can I exclude if the decimal point is 0 ?
LeeJaeYoung
A = 1000 B =1000  => 10x10
A = 1150 B =1120  => 11.5x11.2
in GDL TEXT2
AC27 on window 11
2 ACCEPTED SOLUTIONS
Solution
LeeJaeYoung
I found it.
I can create an IF statement that uses the FRA() function... ^^
AC27 on window 11
Solution
A_ Smith
TEXT2 0,0,str("%~", 11.5*11.2)
there are different flags for STR function. ~ hide 0 decimals
AC 22, 24 | Win 10
3 REPLIES 3
Solution
LeeJaeYoung
I found it.
AC27 on window 11
Solution
A_ Smith
AC 22, 24 | Win 10
thank you ^^
AC27 on window 11
