How do I use the Profile parameter in a GDL script.
I'm new to GDL, I can create basic shapes and write basic code, like IF statements, but I can't figure out how to create a shape using the Profile parameter to inform the geometry. Any help would be most appreciated.
1 Solution
Lingwisyer
Guru
If GLOB_SCRIPT_TYPE = 2 or GLOB_SCRIPT_TYPE = 3 or GLOB_SCRIPT_TYPE = 4 or GLOB_SCRIPT_TYPE = 5 then
	_nComponents = 0
	dim _componentTypes[]
	n = REQUEST{2} ("Profile_components", myProfileIdx, _nComponents, _componentTypes)
	n2 = REQUEST ("Profile_default_boundingbox",  myProfileIdx, _xMin, _yMin, _xMax, _yMax)
	n3 = REQUEST{4} ("Profile_component_info", myProfileIdx, _nComponents, "gs_profile_surface", bMat_profile)
	If GLOB_SCRIPT_TYPE <> 5 then
		If rafPro = "Complex" then
				ProWidth = abs(_xMax - _xMin)
				ProHeight = abs(_yMax - _yMin)
				SquareV2 = ProHeight / ( cos(phi) )
		endIf
	endIf
	if n then
		dim _bShowPart[]
		_needRequestDetails = 0
		for _i = 1 to _nComponents
			_bShowPart[_i] = 1
			  if GLOB_STRUCTURE_DISPLAY = 1 AND _componentTypes[_i] <> COMPTYPE_CORE then _bShowPart[_i] = 0   ! GLOB_STRUCTURE_DISPLAY: 0 – entire structure, 1 – core only, 2 – without finishes
			  if GLOB_STRUCTURE_DISPLAY = 2 AND _componentTypes[_i] = COMPTYPE_FINISH then _bShowPart[_i] = 0
			  if _bShowPart[_i] then _needRequestDetails = 1
		next _i
		if _needRequestDetails then
			dim _profileGeometryRawData[]
			n = REQUEST ("Profile_default_geometry", myProfileIdx, _profileGeometryRawData)		! n1, n2, ..., nn, x11, y11,s11
			dim _contStartPoints[]
			dim _contEndPoints[]
			_contStartPoints[1] = _nComponents + 1
			for _i = 2 to _nComponents
				_contStartPoints[_i] = _contStartPoints[_i - 1] + _profileGeometryRawData[_i - 1] * 5
				_contEndPoints[_i-1] = _contStartPoints[_i] - 1
			next _i
			_contEndPoints[_nComponents] = vardim1(_profileGeometryRawData)
		endif
	endif
endif
There is a sample object somewhere by Graphisoft, but it appears to be alluding me...
There is also an object shared in this thread which is in regards to having multiple Complex Profiles in a single object.
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
Go to post
4 Replies 4
Lingwisyer
Guru
	_nComponents = 0
		endIf
	endIf
	if n then
		dim _bShowPart[]
			_bShowPart[_i] = 1
		next _i
			next _i
		endif
	endif
endif
Ling.
David Maudlin
Check out this thread: Profiles in GDL.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks for the help. Lingwisyer, I couldn't get the code you posted to work but the one in the link regarding 'multiple Complex Profiles' works great. Thank you:
Lingwisyer
Guru
For the script I posted, you need to add myProfileIdx as a profile variable into the parameters list.
I also accidentally left in a section that was specific to my script...
Ignore:
		endIf
	endIf
Ling.
