Hi Everyone,
I have created a modular sub-object (macro) that includes its own Parameter Script to handle dynamic value lists (values commands) and parameter constraints.
I want to call this macro from a Main (controller) object. Currently, it only works if I completely copy-paste the macro's Parameter Script into the Main object's Parameter Script. If I don't copy the code, the dynamic drop-down lists do not appear or work in the Main object's default parameter list.
My question is:
Is there a clean, simple way to trigger or execute a macro's Parameter Script from a Main object without duplicating/copying the code into the Main object?
I want to use the standard default parameter list of the Main object, and I would like to avoid building a custom Interface Script if possible.
Thank you!
Gábor
Operating system used: Windows 10
Versions 6.5 to 28, AMD Ryzen 9 3900x, 32GB ram, GeForce RTX 2070 super, Windows 10
