teammember
How to stop gdl script execution?
Hello,
Im working on a rather large project and some things require some custom simple GDL objects to save some time. Well now and then I end up writing an infinite loop. Is there a way to stop a script at this point? Does it stop on its own after a while? I'm a little worried ending up with a broken file.
Thanks in advance!
3 Replies 3
Lingwisyer
Guru
Does ctrl / cmd period work for you?
teammember
Thank you !
Unfortunately it did not work, Also tried switching the keyboard layout in software vom german to english, did not help.
Im on AC 23 AUT WIN 10 PRO
runxel
Yeah, happens to the best from time to time 😉
In theory Cmd + "." should work, as Ling said, but it never actually anything for me either.
So I fear the only solution is the task manager.... Hopefully you have saved your object ealier! It will then be catched in the auto save file.
All in all another reason why I prefer to not program in Archicad directly.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
