GDL
I'm not sure what the difference between tolerance and oversize is.
LeeJaeYoung
When installing the door, make sure to leave 10mm of space on the top, bottom, left and right of the concrete wall beyond the size of the door.
So is this tolerance? Is it oversize?
AC27 on window 11
1 REPLY 1
Miha_M
Essential difference: Entering an Oversize does not (unlike the Tolerance value) affect the Nominal Size of the opening. For further reading the Help pages also have some descriptions about this topic: Nominal Sizes and Tolerance (graphisoft.com)
Solved: Doors: Tolerance vs Opening Oversize - Graphisoft Community
The above link gives you some explanation about this. I am using the GER localization library, where both terms are one and the same thing - a raw wall opening size.
| Archicad 4.5 - 29
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
