GDL
Is there any example of using the parameter BEAM_SEGMENT_INFO?
taigd
I have trouble using this parameter. 😟 Maybe there is a simple executable example so I can understand how to use it. Thank you.
3 REPLIES 3
Jochen Suehlo
Try to find the macro object "label_content_macro.gsm". There this Global is used.
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
Thanks for the info, I'll give it a try。😀
taigd
It works...
IF GLOB_ELEM_TYPE = 12 or GLOB_ELEM_TYPE = 28 THEN
     IF BEAM_SEGMENT_INFO.segments[1].crossSection.type= 1 THEN text2 0, 0, "BEAM_RECTANGULAR"
     IF BEAM_SEGMENT_INFO.segments[1].crossSection.type= 2 THEN text2 0, 0, "BEAM_ROUND"
     IF BEAM_SEGMENT_INFO.segments[1].crossSection.type= 3 THEN text2 0, 0, "BEAM_COMPLEXCCC"
ENDIF
