scottjm
Mentor
LP_XMLConverter ‘-compatibility’ argument
So I’ve been diving deep into the LP_XMLConverter. A great tool!
There is a -compatibility argument that you can pass an archicad version to the tool. However it only allows this argument to be used when decompiling gsm’s to xml/hsf.
How can I instead compile a gsm for a specific Archicad version? It always creates it for the version of Archicad that I am running the LPXML converter from.
My goal is to be able to decompile for example an ac25 created gsm, make some edits to the xml, and then recompile back to ac25 again to maintain compatibility.
Thanks,
Scott
Jochen Suehlo
See this thread: https://community.graphisoft.com/t5/GDL/Saving-library-parts-under-previous-version/m-p/659455#M7612
Yes, the LP_XML_Converter only seems to be able to work with the gsm files the same version as the converter if you are converting back from xml to gsm.
But if you convert from gsm to xml, you can use e.g. Converter 28 to convert files from AC 27 and downgrade them to 25. But to get the 25gsm file from the 25 xml file, you need to use the AC25 converter.
Yes, but this is possible: you can use for both conversions the LP_XML_Converter 25.
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
scottjm
Mentor
Hi Jochen,
Looks like you’ve already gone deep down this rabbit hole.
This is what I feared that you need the specific version of Archicad LP_XMLConverter to compile that version.
I’m attempting to build a gui wrapper for the LPXML tool, so looks like I’ll be downloading the SDK for every version.
